Mettalic Rattle between 5k-6k
I had already posted about this, but it seems to have disappeared! I have an odd rattle inbetween 5-6k, happens in all all gears (well at least 1-3!).
I have tried searching, but not much luck. Any ideas? Loose heat shield, cat?
Was a Loose heat shield & cat on mine
And mine
And it was always between 5 and 6k?
Just went to the local garage to get it booked in, described the issue, enjoyed the response I got...
'....how often do you get up to 6k!?'
...more often than you'd think!!!!! Obviously doesn't know VTEC!
I wouldn't personally, the cat gets bloody hot as you'd expect, they are there for a reason.
I would just get under the car and have a look your self, it is normally plain to see what's happening. There are also 3 heat shields on the manifold itself plus a locating bracket where the bolts can work loose.
