MB's latest modification thread...
#372
Member
There is all this talk about F20Cs not being tuneable in terms of NA. I honestly don't believe it. eSeM fitted cams to his and had a good 15-20bhp gain.
It's just a case of choosing the correct mods - there are a lot which just don't work. I have Toda cams planned for mine soon
Here's the proof from my last mod thread (copare light blue to red)
"We did a before and after to prove the increase, but all the mods were already on there so really just shows the increase from the AEM alone. I gained massive mid range which you can see below, 30 bhp in some places."
dark blue - MB stock
light blue - Gaspode stock
red - MB Mased
purple - Gaspode Mased.
#373
With full induction and exhaust mods (stage 1 effectively) after fitting the AEM, I picked up the same as MB. Cams and properly set up Throttle bodies would be the next evolution!
#374
Hi guys
Keep in mind one thing that dynos are all different and some of them read a lot of Power
In my terms when i had my car nearly stock , only modes were J's Racing cat back exhaust system ,Spoon flywheel + clutch kit and Greedy Short RAM INtake.
And by the way my car is a JDM model so i should see 250ps.
In reality on the same dyno with the above mods i got only 240ps.
So maybe i have bigger numbers and do not now
nicky
nicky
#375
With the exhaust and intake you would start seeing the car run a little richer, and without the proper adjustments to fuelling etc, and age plays a part, that sounds about right TBH.
#376
Member
Adding an intake and exhaust makes it run leaner.
Spo001, it's a fair point. Does the dyno you went to have any figures for a standard S2000?
#377
Nope guys . No numbers . I guess i am the only S2000 on that dyno !
Apart that when i got 240 ps the car was running more rich as the air/fuel ratio was 12.5:1.
As you all now JDM cars are all tuned on a 100% octane fuel , I guess my car was running rich cause it was knocking all the way with Malta's fuel (89)octane . Very poor fuel (: . Obviously in this way it will automatically retard itself and will rich.
#380
Member
Cheap ones in a sort of satin finish I've spent too much on this car now and need to focus on another purchase. No Rays have popped up for sale since I sold mine either
