MB's latest modification thread...
Old 04-11-2011, 01:28 PM
  #281
UK Moderator
chrisr111's Avatar
Very very nice Mark
Originally Posted by Dixon Motorsports
The spec is very similar to the one they made for a well known Japanese tuning company, I am not sure if I can mention the name yet I will need to confirm this with Nitron. They did a back to back testing with the own spec kit made by Crux and the result was 1.2sec quicker at Tsukuba with the Nitron.
J's Racing used to use Crux before they switched to Showa SPL; I guess they're using Nitron now
Originally Posted by NineBolts
Those rears must be almost solid given that half the travel's been taken up by the helpers. what's the rates 700 rear 650 front by the look of the numbers on the springs? That's about twice as much boing in the springs as I've got.
I'm using similar rate (12 kg/mm) Hyperco springs (+helper springs) on my ASM dampers and the ride is surprisingly compliant even with the bump and rebound turned up mid-way.
Chris.
chrisr111 is offline
Old 04-12-2011, 12:40 AM
  #282
MB
Member
MB's Avatar
Originally Posted by razzele
Originally Posted by MB' timestamp='1302538390' post='20452977
I think I have a semi on
I ve got a full on Rager!!
PM me how much it would be for my own personal Nitron boner material?
Hi Raz, missed your post Give Dixon a call re pricing
Will be doing some reviews on these as I start to use them.
MB is offline
Old 04-13-2011, 06:26 AM
  #283
MB
Member
MB's Avatar
Front wishbones are rusted and have siezed bushed, so Mr Dixon has brushed and painted them, and some Polybushes and new bolts / sleeves have appeared!
MB is offline
Old 04-13-2011, 08:58 AM
  #284
chilled's Avatar
Mark, next time I see you at a track day, I'm taking it for a test drive. By force if necessary
chilled is offline
Old 04-13-2011, 09:05 AM
  #285
s2konroids's Avatar
This is turning into a track day weapon
Have you ever considered FI?
s2konroids is offline
Old 04-13-2011, 09:23 AM
  #286
MB
Member
MB's Avatar
Chilled, no probs There's only a few people on here i'd let use it. Be interested to see what you think of it. Just not at the Ring...!
Irv, FI is for benders
Looking forward, once Dixon has done all the suspension / geo / brakes this week, it just needs Yokohamas fitting and it's good to go for the track season. Wing will be here the end of this month, and will probably just use OEM wheels for now.
MB is offline
Old 04-13-2011, 09:26 AM
  #287
s2konroids's Avatar
So you used to be one .
Old 04-13-2011, 10:04 AM
  #288
Ultra_Nexus's Avatar
Ah Dixon beat me to it
Will be interesting to see how these perform over the Tein stuff I had. I have lots of track footage to compare against, and a consistently average driver as a benchmark
Although my car will be a bit different to the last one with the diff and wing mods.
I am very much looking forward to your report on this comparison. Track wise I don't think there will be much performance difference, not unless you get them specifically setup for EVERY track (which is probably where the 1.2s advantage around Tsukuba came from).
Hvae you gone for the Poly castor bushes though Mark?
Ultra_Nexus is offline
Old 04-13-2011, 10:15 AM
  #289
Banned
r8byb's Avatar
MB just read about you possibly removing the skirts etc.
Ever thought of pairing your rear wing with a diffuser? Would tie the bumper and skirts in well as from a side view the rear would look at a decent height in relation to the rest.
r8byb is offline
Old 04-13-2011, 10:33 AM
  #290
MB
Member
MB's Avatar
Hi R8, if i'm honest i'm not fussed about making the car look right, It's not a show car and anything I do will be for function. I just don't want it to look too modified if possible! Going to be difficult
Ultra, hardrace spherical for the Castor.
MB is offline
Quick Reply: MB's latest modification thread...
