MAP sensor life span
recently had a failed map sensor - long story short when i first bought the car i replaced the map sensor. 1.5-2yrs later the replacement (Denso brand) has gone pop, so im now back on the map sensor that i had when i bought the car.
1.5-2yrs seems way too short a lifespan, yet we all know the S does suffer from map sensor issues.
how long has your map sensor lasted (original or replacement). have i just been unlucky and bought a weak one?
Member
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
They are shite imo. Most cars use them with no issue, so it's either the extreme heat (and the S does get incredibly hot) or contamination from excessive oil carryover from the breather system.
Either way, they don't last.
A bit like MAF sensors on the MY99-00 impreza. And lambda sensors.
how do i know if my map sensor is playing up?
i know the dreaded impreza maf sensor... mine imploded one night about a mile from the house, luckily my knocklink went mental so i nursed i home and switched in a new one.
my map sensor failure felt like fuel starvation (or heatsoak)
as FAQ says, only in VTEC, and mine was evident between 7-8k, and not even a flicker of CEL.
im going with MB - heat and oil combination causing life-span issues. surely thats no different than most other cars now, where engines are shoe-horned in, and lots are now turbo.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
Cut some holes in your bonnet like the yanks do, that'll lower engine bay temps and hopefully extend the MAP sensor's lifespan.
If it's oil related, perhaps a catch can will help?
Member
Catch can is a good idea, but you have to weigh up the cost.
Under bonnet temps aren't the only issue - the block gets so unbelievably hot, and this transfers back to the throttle body where the MAP lives.
The S just seems particularly bad for it.
