Lucid rear panels
I'm not sure that bass speakers come in such small sizes Tintop, simply a question of physics. However, there may be some out there which Mikey K or X Ruckus are aware of. You may be better swopping the speakers for mid range speakers which are well known for their bass.
shifting large amounts of air with the speaker cones and low frequencies (don't pressurise me further Steven, it all too techincal and I may
Erm, not sure how the HU would drive sub speakers as well - you may have impedence problems
![cry.gif](https://www.s2ki.com/forums/images/smilies/cry.gif)
![thinker.gif](https://www.s2ki.com/forums/images/smilies/thinker.gif)
![](https://www.s2ki.com/forums/images/s2ki/ranks/gold_member.png)
Mid range is the easiest option as the kit is being run from the head unit, All the speakers I have seen though come with birdies andI can't see the need for them as you already have two near your ears. The acoustics in the car seem to peak between 4khz and 5khz so I don't want to boost this range anymore and mids might do this. Its around 100Hz where things go so thats what needs tweeking.
My guess would be two 5" speakers should have the same push as one 8" sub?? Mayme a separate amp to drive them.
Subs behind the seats should be so
It'll feel like your farting.
![cool.gif](https://www.s2ki.com/forums/images/smilies/cool.gif)
http://en.wikipedia.org/wiki/Subwoofer
Have you thought about aural bass shakers, as per Mikey K's setup?
UK Moderator
![](https://www.s2ki.com/forums/images/s2ki/ranks/moderator.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Craig is basically correct.
In order to produce low frequency sounds at a certain volume, you have to shift a lot more air than you would to produce higher frequency sounds at the same volume. In order to shift more air, you need a larger speaker area (which is why subs are usually 8" upwards), as well as a more powerful amplifier to move the speaker.
Whilst you can produce very low frequencies with a small speaker, it would have to move a very long way back and forth to do it, which results in a flapping noise, which is why we have larger diameter speakers for low frequencies.
The reason subs are bigger is also to do with surface area.
2 6" subs have a surface area of 2 x (pi x 3 x 3) = 56.5 square inches
1 12" sub has a surface area of pi x 6 x 6 = 113 square inches - double the surface area.
You can cheat a little with subwoofer speaker sizes by attaching them to tubes or boxes but this is not an option if you want to use the Lucid panels for the install.
Craig's suggestion of getting some decent quality mid rangers for the rear panels is a good one, especially if you can apply a crossover (low pass filter) to them, either from the HU or using the crossover supplied with the speakers.
![iagree.gif](https://www.s2ki.com/forums/images/smilies/iagree.gif)
Don't forget there is a seat in the way
![wink.gif](https://www.s2ki.com/forums/images/smilies/wink.gif)
I went for the Bass Shakers as they do not need the power or surface area of a sub, but still let you "feel" the bass. I do have an amp so I have used the rear channels of the HU to drive them. They are easily adjusted from the HU this way.
I
![heart.gif](https://www.s2ki.com/forums/images/smilies/heart.gif)
Okay, I can see the idea behind the bass shaker but does it get around the issue of loosing the lower frequencies when you are driving.
I plugged in a frequency generator into the HU at the weekend and listened out for peaks and troughs. Mid range 4000-5000 Hz gets amplified big time by the car, 60 - 150hz gets lost especially when driving.
I want to compensate for these withough using a graphic equalizer, I also have an issue with space. The rear panels seem an option but they are small so no sub. Need to track down some quality mid's without any tweeties and it sounds as thought I should get a quality amp. Maybe a Sub later in the sides of the boot?
I will eventually get an equalizer to try and get a neutral as poss sound. I spent a LOT of money on my Hi-Fi at home I would like somthing in the car that dosen't sound crap.
Thanks for all you help guys, its looking as though those Lucid panels are gonna be back in the MM auction again next year.
