Low idle
Old 10-06-2009 | 09:34 AM
Spies's Avatar
Default Low idle
Have only noticed this recently when manouvering at low speed e.g in to a parking space. When coming off throttle the revs are dipping below 1000rpm causing a slight judder, it recovers than idles around 1100rpm is this too low?
Would I be right thinking either the MAP or ICV might be the problem?
Old 10-06-2009 | 09:37 AM
Lord-Jaffa's Avatar
Mine sometimes does this as well, when coming off the clutch it dips below 1k and judders a tiny bit sometimes when manouvering to park.
Old 10-06-2009 | 09:38 AM
Bandit_287's Avatar
Nope its perfectly normal. If you do an ECU reset and then the idle learn process(see FAQ) it does make things better for a while until there is a substantial change in ambient temperature.
Old 10-06-2009 | 09:57 AM
steve curtis's Avatar
great one , i was going to search on the same thing this eveing as mine has started doing the same.
Old 10-06-2009 | 10:17 AM
Spies's Avatar
Hehe must be temperature related then!
Old 10-06-2009 | 01:59 PM
J_D's Avatar
J_D
Normal, especially when cold. After a ECU rset it will be worse until it learns.
Old 10-06-2009 | 02:19 PM
MB's Avatar
MB
Member
ECU learning takes 10 mins.
ECU reset can just mask the problem for a very short time, not usually solving the problem.
Old 10-06-2009 | 02:37 PM
loftust's Avatar
MB's Idle Thread now in my sig...I've been recommending it alot recently and may prove worthwhile to the OP in the long run.
Wisconsin S2k
03-25-2017 01:55 PM
unclefester
02-21-2010 12:43 PM
Apex_AP1
04-06-2008 02:02 PM
kalibo
09-21-2007 10:07 AM
Saxo Boy
04-01-2006 11:14 PM
