A litttle hardtop help please.
Hello,
I want to order the full fitting kit from Jeff at hardtopguy.
Just a little confused about the wiring when it asks;
"Does the defroster wire connector on the hardtop have 2 wires or 3".
Is this the connector behind the passenger door trim or just behind the passenger headrest?
I can see three pins behind the headrest and already have the defroster switch fitted.
Hope I'm not wasting time asking a question covered time and time again.
Thank you.
Thank you.
You should have a piece that will plug into the hardtop wiring when you have it..basically it has a lil rubber boot that is now part of the side panels
when the hardtop is down you plug it in
it will have 3 pin but you might just have a brown and black wire in it.. mine has the center empty
