lightweight flywheel's
as the clutch on my S is on it's last legs,iv purchased a act clutch and i was going to fit a lightweight flywheel whilest the box was out.Which brings me to a question has anyone on here used or using a lighter flywheel and whats it like as there are so many differant weight's?
I believe that a lightweight flywheel will make the car more difficult to drive as a daily driver.
At some point the OEM flywheel changed beween MY models and gained a bit of weight. When I had my ACT clutch installed I went for the original OEM flywheel and the car drives just like stock ... which was what I wanted.
Having installed lightweight flywheels on a number of vehicles (including an ITR and Prelude Motegi), I can tell you that the driveability doesn't suffer at all.
However, the revs do drop faster between changes so you will need to be quicker in order to match.
Toe & heeling is easier as well.
Lighter the better though
UK Moderator
22100-PCX-005
So the flywheel has never changed on UK S2000s.
In the US, the S used this flywheel until 2003.
In 2004 when the AP2 was released the flywheel changed to:
22100-PZX-005
and I believe is around twice as heavy.
Chris.
For a completely flat 'track' yes for the road 'no' - well IMO, on a road I'd rather have over-all driveabilty.
I haven't fitted one before, but i know the theory behind them and there are a few people i have heard who have regretted it.
I dont agree with Ron though, lighter the better. Obviously more get up and go with a lighter flywheel, but too light and driveability will suffer possibly more so as the flywheel will be quite light to begin with - Honda have used little tricks like this.
I do agree with Ron about the revs, after all its just heavy disc.
Originally Posted by andy s2k,Sep 14 2010, 10:25 AM
so it doesn't matter how light of a flywheel i get then,and what would they mean by affect to daily drive???? in what way would it affect?
Where every action has it's reaction, so this advantage has a disadvantage - the drivetrain has less inertia once it's up and running, so it reduces more quickly when you lift of the throttle (relatively speaking) - making it more prone to stalling (in theory at least).
Remember - theory and practice are the same in theory, but not in practice...
I've had a Fidanza flywheel (8lbs) with an ACT 6 puck clutch and it was absolutely rubbish in traffic! Hill starts were a nightmare as the clutch was just like an ON/OFF button! It had no play or travel whatsoever.
On the other hand I'm using a Competition Clutch stage 2 with an 11lbs flywheel and the car is as driveable as stock but does have a slighty quicker pickup.
Seriously - i'd recommend getting one.
Rotation weight is poop and you don't want it.
Yes, at low revs, it will stall easier, but it's not as if the S is a difficult car to drive.
In the cars I have driven with light flywheels in, they present no issues whatsoever
