leaking roof?
Seriously though, you may need to grease the rubber seals. Mine used to leak a little round the windows when I hosed the car down until I put some silicone grease on them, now they feel rubbery again and don't leak.
Where specifically is it leaking?
they was using pressure guns. there is a slit where the roof folds down from the window seal. seems to be leaking from there. not a lot but just one of those things that isnt needed when you buy a new car.
Its the split in the rubber seal in the middle thats causing me grief.
Mine does this too.
Only started happenning just after the car was 3 years old (typical!)
Again, its where the split in the rubber seal is.
It doesnt leak badly, and its only really noticeable whilst driving in heavy rain but nevertheless its still annoying.
However, the rubber seals all look intact, and there is no visible deterioration on the rubber.
I jetwash mine at Sainsbury's, but only get the odd drop inside occaisonally (and I mean literally the odd drop).
As long as you don't direct the jet straight at any seals it shouldn't leak IME.
Gaz, you can get the grease from a stealer - part number might be in the tech faq. It's about
