Judder when accelerating
Old 03-04-2008, 12:31 AM
  #21
MB
Member
MB's Avatar
Very good of you to update the thread
Old 03-24-2008, 03:37 AM
  #22
Administrator
AquilaEagle's Avatar
Been told to check my bearings first before I do halfshafts.
How would I do that?
Old 03-24-2008, 10:19 AM
  #23
RISLAR's Avatar
Hi Ian, you'll need to jack the car up and place your hands on either side of the wheel, now see if there is any play in the bearing by trying to move the wheel from side to side, you will know right away as there will be play in the wheel, these can also be tightened if they are loose
Old 03-24-2008, 10:21 AM
  #24
Administrator
Thanks mate... pretty sure Chris did that when I had my corner weighting done
Half shafts it is then... SO if I ask for them, will a breaker know what I am on about?
Will 04+ half shafts fit a 2002?
Old 03-24-2008, 10:28 AM
  #25
RISLAR's Avatar
Yep, i'm pretty sure that all them parts are the same right across the range, someone will be along to confirm though, as they do
Old 03-24-2008, 11:35 AM
  #26
Mans Best's Avatar
Hi Ian. I'm sure they're all the same regardless of model year. Fenland helped me out when I needed to do this. The vibration/judder is quite a 'heavy' vibration and not akin to bearings if you ask me. Trouble is, you'll struggle to know which side is the problem until the halfshaft is actually replaced. I had my nearside only done (because Fenland sent me two nearside shafts by mistake!) and that cured it without having to do the offside.
Old 03-24-2008, 11:36 AM
  #27
Administrator
Thanks Brian.... So do you still have a spare n/s ?
Old 03-24-2008, 11:49 AM
  #28
Mans Best's Avatar
I have an off-side still in Fenland's cling film. If you need it (see my earlier comments about it being difficult to identify which side has the problem) I'm sure we can come to an arrangement
FIRSTCAR-S2K
10-23-2015 05:27 PM
Russ Watts
07-07-2013 06:55 PM
Cudder
07-24-2011 09:45 AM
SenseiRick
07-17-2003 12:07 PM
SJSHARKS
01-27-2003 03:59 PM
Quick Reply: Judder when accelerating
