Jenson
Old 07-17-2010, 09:24 AM
  #551
p800bry's Avatar
My Engine was replace 1200 miles ago by Honda, but they could not find any evidence as to what was actually wrong with it other than a knocking noise coming from the rear of the engine
The original engine number was F20C2-1070481
New engine number F20C2-0109023
So going by the numbers it would appear that the new engine fitted in my car is actually a fair bit older than the original one which hopefully is good news seeing as it seems to be the later engines that fail.
Old 07-17-2010, 09:37 AM
  #552
p800bry's Avatar
Just seen that your latest engine is older than mine so that's my theory dead and buried lol
Old 07-17-2010, 09:52 AM
  #553
UK Moderator
chrisr111's Avatar
Your original engine was built in 2007
whereas you new engine was built in 2010
so your new engine is actually newer than the old one
Chris.
Old 07-17-2010, 09:56 AM
  #554
UK Moderator
chrisr111's Avatar
Originally Posted by Elijah,Jul 16 2010, 05:12 PM
But given the range of engine numbers I'm aware of, not sure whether that'll help.
In numeric order:-
F20C20108020 (my new engine, just failed, 21k miles on engine)
F20C21080571 (Jenson)
F20C21080681 (my old engine, 9k miles)
F20C21090153 (Snowy)
F20C20108020 built 2010
F20C21080571 built 2008
F20C21080681 built 2008
F20C21090153 built 2009
HTH
Chris.
Old 07-17-2010, 11:26 AM
  #555
Trip's Avatar
What mileage did the engine fail at ?
Mine has only 5.7K Miles and running strong. On my next service, I will make sure they will check the old oil for any debris.
Old 07-17-2010, 11:49 AM
  #556
p800bry's Avatar
mine never actually failed, it just made a knocking noise that I noticed a few days after I bought the car with 13k miles on it. I then drove it for about 7k miles and the noise never got any worse, the engine never used any oil at all and made 193 whp on the dyno so all seemed good but the noise bothered me. I waited till the end of winter and decided to get Honda to check it out (while still under warranty) where they said it shouldn't make the noise it was making and fitted a new short block. Even with the Block out of the car they could not find anything visually wrong (no crank end float, no scored bores, no swarf in the sump) so they just sent it back to Honda without ever knowing what was wrong with it.
Old 07-17-2010, 11:52 AM
  #557
p800bry's Avatar
Chris.
So they carried on building F20C engines long after they stopped building cars that they could put them in Well I hope they built my latest one better then my old one
Old 07-17-2010, 11:55 AM
  #558
p800bry's Avatar
so the engine numbers are date related and not just numerically ascending e.g 000000001,000000002 etc
Old 07-17-2010, 12:23 PM
  #559
Elijah's Avatar
HTH
Chris.
My new engine was fitted in early 2009 - so this decoding of the engine numbers appears incorrect??
F20C20108020
Old 07-17-2010, 01:32 PM
  #560
UK Moderator
chrisr111's Avatar
I've just done a little bit of research, I thought the engine serial number had a date identifier, but apparently not.
The engine numbers are sequential.
However, the first F20C2 would be:
F20C21000001
not
F20C20000001
Chris.
Quick Reply: Jenson
