Invidia Exhaust
Invidia Exhaust
Hi all,
I have recently purchased a MCB S2000 which had an Invidia exhaust fitted. I also have the stock one and am in 2 minds whether to sell the exhaust and put the stock one back on or doing some research I have seen reference to bungs. Do the bungs just quieten down the sound and does anyone know how it would sound compared to stock with the bungs in.
Does anyone know where I can get them from and how much they would be and if they are easy to fit. I note that there is a small hole in the bottom of each pipe, is this where the bung would be secured.
Thanks in advance for any comments.
The bungs would quieten it down, but not to anywhere near the level of the stock exhaust. Try youtube for audio clips.
I don't know where you could purchase them, but yes, they would attach using the holes in the tips, and are very easy to fit...even for a mechanical retard
Thanks I will check youtube, that sounds the solution as I don't want to quieten down to stock levels but I find the drone a little annoying on long motorway journeys, that said, it sounds great in the lanes when blasting through the gears. Also the flexibility to put in and out would also be good. Now I need to source some.
You may tame the drone a little bit, but aftermarket exhausts have inherently alot more drone than the OEM system, which is really rather good at keeping it to a reasonable level.
I have the bungs for my invidia and there is a noticeable difference in noise. worth buying if you can find a set, I would video a before and after but there hidden deep in my shed somewhere.
where are you located mate?
i have a invidia cat back with bungs in and bungs in it sound ok ish but a bit boooooring , bungs out it sounds insane but wow its loud with bungs out
if your anywhere near dorset came come listen to mine if you like?
