Important Clutch Operation Question, AP1 and AP2 Different
Does anyone know if the AP1 and AP2 use different clutch operation systems?
ie does one model have a pull type system and the other a push type system?
Any information would be greatly appreciated!
Yes you guessed it almost. Reason for asking this question was because we were having problems getting the clutch release bearing to marry up with the clutch and were convinced it should be a pull not push system. Turns out we had been supplied the wrong bearing which was a push one. A quick call to Hendy Performance, and yesterday the correct bearing arrived in record quick time. Engine will FINALLY be in the car next week, then its time for some serious work to start on it!
