Immobliser wont go off im stuck at work, help
Old 09-17-2008, 11:38 PM
Nottm_S2's Avatar
you cant re-program if the fob you have isnt working, you need a working one don't you?
ah well... he's probably just getting his date breakfast after a quick cab home
Old 09-17-2008, 11:47 PM
pistonbroke's Avatar
He said earlier that the LED is lighting up when he presses the fob, so it must be sending a signal.
Old 09-17-2008, 11:56 PM
RevRanger's Avatar
No, she's probably stuck IN the car, hence the urgency!
Old 09-18-2008, 12:01 AM
s2konroids's Avatar
Could you not ground the fuel pump wire, i had to do this with my spoon ECU so the car would start.
Or i could be taking bollocks
Old 09-18-2008, 09:15 AM
surfer_crx's Avatar
Well the date went very well despite my cars best efforts to foil it.
So I went into work today, on a day off, armed with the keyfob and a brand new battery of the correct type, and still nothing, the light on the fob works but when I go to press it, nothing happens in the car.
I rang Honda and they said that opening the car with the key should switch the alarm and immob off, but I tried this a few times last night and didnt have any joy, they said they can take a look at it but it will cost
Old 09-18-2008, 09:43 AM
darrenswift's Avatar
I recently had a very similar experience to you mate, had to get the car towed in (on a flat-bed) to , eventually, get the alarm circuit board replaced. If you're pretty handy with a spanner/confident working on your car, buy a replacement board from Hamilton & Palmer (about 130 quid) and fit it yourself. All you need to do is take out your driver's seat, remove the lid from a metal box and replace the (probable) fried board.
The purchase alone would be cheaper than Honda's quoted price. H&P also send you reprogramming instructions and a new fob!! Bargain.
Most people recommend getting the alarm swapped, although I didn't know that at the time. I paid Honda 300 quid for the privilege
Old 09-18-2008, 09:47 AM
surfer_crx's Avatar
Thanks for that info, I'll have a look at it tomorrow, if its just dry joints or a visibly burned out component on the board I should be able to sort it tomorrow, fingers crossed
You won't be able to just rip it out, cat 1 alarms are 3 point systems, ignition, fuel pump and starter. Ripping it out will not disable the fact that these three points are still immobilised.
There are mobile alarm fitters that come out to do alarm installations. I used one on my supra. Bloody brilliant deal. Cobra cat one alarm with global closing fitted
Old 09-18-2008, 11:53 AM
RobH's Avatar
I've just removed the imobilisation circuits on mine as the same thing happened with the alarm giving up on me.
The thread with rough details of what I did is here https://www.s2ki.com/forums/index.php?showt...&#entry14240912
Again - if it helps and there's anything else, let me know!
Rob
baz2000
08-02-2016 07:52 AM
andy2000
09-12-2012 08:53 AM
taffyb
11-22-2007 02:00 AM
JamieS2K
10-19-2005 12:05 AM
marc r
03-05-2005 12:30 PM
Quick Reply: Immobliser wont go off im stuck at work, help
