Immobiliser problem and lights on chime not workin
OK, i searched and tried various things but the Immobiliser 'key light' isnt comming on, also the lights on reminder/taking the key out beep isnt working.
Apart from taking it to Honda is there any way to check if the immobiliser is working?
Also is there a seperate beeper unit/fuse or is it integral to the immobiliser?
The car was jump started by the AA a while ago, could this have blown something?
![ponder2.gif](https://www.s2ki.com/forums/images/smilies/ponder2.gif)
I had a similar problem with the chime on mine, turns out it is a dodgy door switch that turns on the interiour lights. Check out the switch, you might get away with cleaning it with electric contact cleaner or you might need a new one from a breakers yard.
All the fuses have been checked. There isnt one listed for the chime tho.
The door switches work fine, as i said its the chime that isnt working on either lights on reminder or the immobiiliser.
DodgeViper01
01-03-2016 11:29 AM
