ideal tyres size on a 9" rim
Hello everyone
I will be getting my new wheels soon. 17x9 et42 all round and i need to sort out what tyres to get. I basically have a couple of options
Option 1 being 245/40 all round (worried front may poke out too much)
Option 2 being 225/45 front 255/40 rear (worried that a 225 will have too much stretch and 255 will rub)
Option 3 being 225/45 front 245/40 rear (worried that a 225 will have too much stretch and the two rolling sizes are about 10mm different)
Option 4 being 235/40 front and no idea what on the rear
Bit lost now on what to think and what works well front to back.
Note - 245/40/17 on this wheel will not rub on standard suspension as there is already a guy on here running this setup. I will be getting my arches rolled as soon as I get round to making my mind up on how I want to lower the car
All thoughts will be greatly appreciated
Regards
Harvey
Regards
Harvey
Sorry I never noticed you put the offset,I am running et 38 offset.Be careful having the arches rolled, if you check out my build thread you will see the problems I had.
I would think with et48 + 255s and having your rear arches rolled you should be Ok with a 30mm drop but you may have to move the bumper tab.
So the stretch on your 9.5 rim and 235 tyre up front will be very similar to a 225 tyre on a 9" rim, I've looked through your threads and couldn't find what I was after, is there any chance you would have a picture of the stretch? Just want to make sure it's not ott
it also all depends what profile tyre you go for
a 225-35 will have more stretch then a 225-40
use the website www.willtheyfit.com to get a 100% accurate idea of how it works.
Well if needs be I will have to run more aggressive camber to eliminate the rubbing. Lowering is the next on the list and I will have to do some research to find a spring that has similar characteristics as standard. Maybe a little stiffer
