I wouldn't say I was stupid
Banned
this should go in the tech faq...........
removing refitting the door mirrors is (can be) a pain - identical either side btw
door card removal is simple, as is the electrical connection
the mirror is then held on with three studs and bolts
the studs are part of the mirror assembly, which pass through three holes in the door and are then bolted up from the inside
now two of these are easily accessed with a 10mm socket on a straight extension
but the third stud and nut, which is to the rear of the car, is blocked by the window frame
you can get it off, but only by using universal joints and extensions on your socket and there is a very real risk of dropping the nut into the recesses of the door bottom. refitting though, is an absolute nightmare, even with soft delicate hands like mine
I had struggled for over an hour to refit my mirrors - just with this problem stud and nut
On the point of giving up or breaking something, I decided to try something else, which was to fit the replacement speakers
Guess what? With the speaker out you can reach up and put the nut on with your bleedin fingers! You can also get a small ratchet inside the door via that route and nip everything up tight. Job done in under five minutes.
So bear this thread in mind - it will drive you crazy trying to do it 'my way'
or the thicko route as it shall henceforth be known
I found that out whilst once straightening a dented door, for practice. But I'd forgotten.
Actually, I hate doing anything that involves doors. You can NEVER get to the bit you want, there's always the risk of rattles or broken clips and I always end up covered in farking mastic.
Banned
to Nick for his speaker upgrade recommendation
Kenwood KFC-1666
straight swap for the oems (apart from connectors) even the splash guard fits perfectly
a VERY easy and cheap upgrade
you can pick up a pair of these speakers new on ebay for about
Kenwood KFC-1666
Banned
Originally Posted by baptistsan,May 16 2006, 07:49 PM
Do these come with tweeters?
spec from the box says:
6" 2-way
peak power 130 watts
digital ready
woofer 158mm
tweeter 35mm
[QUOTE=gaddafi,May 16 2006, 07:14 PM] to Nick for his speaker upgrade recommendation
Kenwood KFC-1666
Kenwood KFC-1666
Oh, well.
My life's like that. Took me five months to find an Accord mirror switch, so I could nick the PCB to repair the heated mirrors. The amount of non-delivered 'Lude switches, non-replies on Ebay messages, etc, etc.
Banned
Originally Posted by Nick Graves,May 17 2006, 09:34 AM
Oh, well.
