How much has StevenM spent on his car
Old 07-26-2005, 12:05 PM
  #21
Paper Lawyer's Avatar
they seem like very simple mods to do. You'd have to be a moderater to cock them up!
Old 07-26-2005, 12:10 PM
  #22
eSeM's Avatar
Originally Posted by The Boy Wonder,Jul 26 2005, 02:26 PM
I suggest you bring the bits with you and we do it at Roadies place....group effort ya know
Excellent idea! I have a fuel pressure regulator that I could bring along and we could install at the same time.
If it works we can de-install it at the next Herts meet and install it on to my car
Old 07-26-2005, 01:50 PM
  #23
UK Moderator
chrisr111's Avatar
When I had mine, I got my dealer to change the thermostat.
But it only take 5 minutes to change the ECU once you know how.
However, UK spec S2000s have anti-tamper bolts (kind of like rounded off triangles) holding the ECU in place.
There are three bolts in total. Two hold the ECU in place and the third holds a metal bracket in place which need to be removed in order to unplug all of the connectors.
Once you have these bolts removed, you can replace them with standard hex bolts (Honda part number 93403-0602008).
I removed the triangle bolts with one of those press-in-pin sockets that is designed for removing rounded off nuts etc.
Hope this helps.
Chris.
PS you should get better fuel economy with the Mugen ECU as it runs the engine much leaner than the standard ECU.
Old 07-26-2005, 11:17 PM
  #24
Xd
Xd's Avatar
Good points Chris, I will take them into account.
Think I am gonna leave this until after Arran, combination of can't be bothered and lack of time.
This Fuel pressure regulator you have Steve, is this the one that failed on the space shuttle
Old 07-26-2005, 11:22 PM
  #25
eSeM's Avatar
I asked my dealer to replace the bolts when the car was in for a service
Old 07-26-2005, 11:25 PM
  #26
new shocks today Steven?
Old 07-26-2005, 11:28 PM
  #27
eSeM's Avatar
Any tips on settings?
Old 07-26-2005, 11:33 PM
  #28
I'm currently running my rebound 10 clicks from full soft (full soft being turned completely anti clockwise). This gives a nice ride and without the rear end sloppiness you get with the OEM rear dampers.
You'll probably find it easier to feel each individual click when turning it from full hard i.e. turn the adjuster fully clockwise and then turn its back 8 clicks (as there are 18 clicks of adjustment).
I tried the dampers at 4 clicks from full hard last weekend - better suited to smooth roads and the track
Old 07-27-2005, 12:11 AM
  #29
Xd
Xd's Avatar
How many clicks do you need to stop the exhuast being shaved on the rebound of an Arran take off?
Old 07-27-2005, 12:12 AM
  #30
eSeM's Avatar
At least 20 I would think
Quick Reply: How much has StevenM spent on his car
