How Loose is Your HID Connector?
As per the title really, even with the retaining clip (Refer to point A in the diagram) holding the lamp in, the connector is still a wee bit loose in the projector assembly.
I tried moving the retaining clip further back (blue line) to clamp it in tighter, but just couldn't put the clip into the lugs afterwards, so I ended up putting the metal clip as per the red line, which is how it was before...
...and yes, the HID lamp is in the connector the right way round
I'd like to know if this is the norm, or if I'm just being a jackass
From when I changed my bulbs, I remember the connector being on, but it wasn't the type of secure fit you get from other Honda connections - the MAP sensor for example snaps into place and the HID connector doesn't.
Dont know if this is of relevance but when I changed my HID bulbs i found that the grooves on the replacement bulbs not quite the same shape as the original so they woulkd not push into place properly so I had to file it a little so it would fit in and metal clips fit back into place securely
Originally Posted by loftust,Dec 3 2009, 01:05 PM
Did you guys have to file the lamps to fit into the connector, or into the projector assembly correctly?
Had this problem AGAIN today on another S. I managed to get the N/S one back in nice and snug. But on the O/S, I just cannot put that stupid fecking metal clip back where the blue line is (refer to OP), it doesn't engage with the retainers for the clip itself. When the clip is where the red line is, it can waggle about far too much for my liking when in the retainers.
My back is broken, fingers ache like a bitch and I'm not a happy bunny
