How do you get the numberplate surround off?
Undid the 2 bolts but there appears to be some square plug things either side holding it in.
Bought myself a short plate - so I assume I'll have to get these filled
i've been looking into this, the two options i've heard about are
a. cut the surround down the middle, obviously no use if you want to use it again, and slide it apart.
b. take the front bumper off and unbolt the fixings from behind
hope thats some use as thats all I know about it so far, hopefully some one will come with some better solutions
Originally Posted by Blurter,Apr 14 2006, 02:09 PM
Do you have instructions Simon?
http://www.ricks2k.com/info/instructions/diffuser.pdf
Originally Posted by simonprelude,Apr 14 2006, 01:19 PM
To be fair to remove the bumper is about a 5 minute job, the force needed is a little more than I thought but it pops on and off fairly easily.
It was on my 00 car but the 04 bumper has a ing akward set of fixings around the headlights.
I dremeled the plate holder out round the bolt, you could use some touch up paint on the bolt left behind.
I have a quote of
I took my bumper off to remove mine, it was a half an hour job by myself and includes putting it back on. It's not hard at all, all you need is a screwdriver and 8 and 10mm sockets. I used Ricks guide
I covered the holes with some plugs I made myself:
Looks a lot better without that plastic thing.
