How do I tell VSA is on, just by looking?
Hi, this might be a silly question but I picked up my new S last night and when I pressed the VSA button, there didn't seem to be an obvious sign whether it was on or off. I see a VSA light on the fascia but it only lit up when turning the ignition on.
My manual is in German so any help would be great
Does anyone know if it's possible to find online/downloadable handbooks? or if it's possible to order new ones from Honda UK?
Thanks
Simon
Thanks
Simon
Administrator
UK cars do not have VSA, Simon. It is a factory option, with 16 weeks lead time. You'd be better asking in S2000 Talk
Congrats on the new car - now we need pics, and update your profile!
Will update my profile now, and will try to do some pics tonight. I sent some to work from home last night but they seem to have got lost somewhere along the way!
Car is great but the dealer misunderstood when I asked him to remove the side Honda badges and he took the S2000 badges off as well...looks weird without them so have to get some new ones put back on.
I would imagine pressing the button (to turn it off) would light the icon on the dash as a warning, then with it switched on it should flash when it kicks in.
Well that is how it works on the NSX so I would have thought it would be similar logic.
By default VSA is on, I don't have my users guide handy but I believe that you press and hold for a few seconds to turn it off. From memory I did this and an icon lights up on the dash.
I guess that having a VSA button means you have VSA (I'm assuming this is the case with my car !!!!)
VSA = Vehicle Stability Assist
Traction control, in other words.
Some blurb:
"Also new for 2006 is Honda's Vehicle Stability Assist system, making the S2000 more stable and forgiving than ever during street driving or in inclement weather conditions. Working in concert with the Drive-by-Wire system, VSA continuously monitors yaw rate, steering input, throttle input, and braking pressure to determine if the car is following its driver's intended path, and can independently coordinate each of the disk brakes through the 4-channel anti-lock brake system, along with the throttle, to enhance vehicle stability. While this serves to effectively enhance driver control during acceleration, braking, and cornering, the system can be disabled with the touch of a button when conditions warrant it."
Some blurb:
