Hot brake disc
Old 09-22-2011, 01:28 AM
  #21
richmc's Avatar
Originally Posted by Spies
Originally Posted by richmc' timestamp='1316681423' post='20994499
Now that sounds like the pad you are looking at is slighty larger than one that has previously been on the car and had caused the original disk ware, if you put new pads on and they overlap the ridge on the disk then I would change the disk as well as the pad won't be contacting the disc correctly till it's worn in.
If the new pads sit off the ridge you have no problem. Could be someone tried some fancy pads in the past that wern't to OEM spec.
Well I have pagid ones to put on, will have to measure them to ensure they're the right diameter for the disc.
Out of curiosity how much am I looking at for 2 new oem discs?
Will get pictures when I get the wheels off again, at work at the moment and struggling to find any time in the evening.
OEM!!! £86.15 + VAT rear each, &137.83 + VAT front each.
Local motor factor or online retail £35-40 each, and you don't need grooved or drilled.
Old 09-22-2011, 01:46 AM
  #22
richmc's Avatar
Or the ever popular auction site,
Item number: 270270648025
Item number: 170386204370
Item number: 390193249804
That I won't mention or post links to.
Old 09-22-2011, 02:06 AM
  #23
Spies's Avatar
Those are all rear brake discs, just so we're sure we are talking about the right thing, when I say the back pad, I'm talking about the one behind the disc on the front wheel not the rear pad on the rear wheel.
Old 09-22-2011, 02:11 AM
  #24
richmc's Avatar
In that case...........
Item number: 270511727379
Item number: 290441690514
Item number: 290595840997
Item number: 370539181636
As I'm not at work and don't need to sneak a look!
Old 09-23-2011, 10:41 AM
  #25
Spies's Avatar
Fluid changed, sliders cleaned and greased, pads changed, both discs feel like the same temp now (******* hot).
Heres what the old pads looked like when they came off, still plenty of meat on them too.
Old 09-23-2011, 11:42 PM
  #26
richmc's Avatar
Yep, thats just a slightly wider pad bedded into the wear patten of the disc, very narrow so if the new one is the same it will bed in nice and quickly. But be aware untill it does the contact won't be perfect so easy on the pedal.
Old 09-24-2011, 02:58 PM
  #27
Paper Lawyer's Avatar
Yes, today I've got myself a siezed caliper as well, actually diagnosed correctly by QwackFart I had been hearing a slight brake noise at low speed, luckily for me still 2mm of pad left so the disk was OK. Cost £231.75 for a refurbed unit including pads and fitting, I don't think that's too bad.
Sounds rather expensive to me. I sourced a refurbished caliper from JRT after doing a search on here:
http://shop.instant-shop.com/JRT-Aut...ry2550649.html
Old 09-25-2011, 12:23 AM
  #28
richmc's Avatar
Including fitting, and with pads. And I kept my hands clean, Guaranteed & pads for life, I don't think that was too bad, the caliper was down as costing £165 (£40 more than JRT) pads £54.80(ouch! but will never have to pay again) and £11.95 for break fluid and bleed. And labour time absorbed into the prices.
A damn site less than Honda would charge.
A. Dos Santos
07-05-2015 07:55 PM
S2K-Phil
10-15-2011 12:23 PM
c32b
03-23-2011 03:24 AM
StealthimageS2k
07-08-2006 11:33 PM
vin02s2k
10-07-2002 10:20 PM
Quick Reply: Hot brake disc
