Hood splitting - warranty replacement likely?
After seeing all the discussions here about hood wear, I checked mine over because as a Jan 06 car, the Honda 3yr warranty expires in January 09.
I noticed it is starting to split on the passenger side just above the passenger door join. There is also some very very slight wear inside in the usual place, however inside is not visibly serious yet.
I wondered whether I would be likely to get the hood replaced as this split only likely to get worse and I'd be gutted if it starts letting water a few months after the warranty expires?
I'm nervous of taking it in to Honda without getting some advice from you guys here in case they try to fob me off with a glue repair or tell me it's normal wear and tear.
Any advice would be appreciated.
Drivers side
Passenger side
Drivers side
Passenger side
Drivers side
Passenger side
Drivers side
Passenger side
I have been monitoring if it is ripping and doesn't show any signs of anymore movement.
Something to look out for though is the plastic guide that is under that area. If the guide goes the wrong side of it (on the out side) then the roof join is put under pressure and can start it tearing.
Here is the thread i started.
Torn Roof Thread.
wingnutLP
01-30-2006 11:19 PM
