Hondata Heatshield Gasket
Old 02-12-2007, 06:20 AM
eSeM's Avatar
The Hondata also stops the the heat from the engine block from heating up the intake manifold.
Even if you install the Hondata you need to do a coolant bypass as the Hondata only blocks off the one end of the flow through the manifold.
Bypass Details
Old 02-12-2007, 08:17 AM
AndyDoh's Avatar
I saw you'd put that in your post but it took at least 4 minutes for my brain to register and by that time it was just too late
Still hung over
Old 02-12-2007, 08:31 AM
eSeM's Avatar
Originally Posted by Andrew Doherty,Feb 12 2007, 05:17 PM
Still hung over
From Friday night ??
Old 02-13-2007, 12:20 AM
Xd
Xd's Avatar
SO what improvements has it made Steven? Even less kangeroos?
Old 02-13-2007, 12:53 AM
eSeM's Avatar
It should give the car a few extra HP in warmer weather.
Old 02-13-2007, 12:59 PM
Trung_EP3CTR's Avatar
Technically it doesn't give the car more HP. It prevents the engine from loosing power in hot conditions.
It's a well worth add-on.
Old 02-13-2007, 01:11 PM
MB
Member
MB's Avatar
Im not sure its in the worthwhile category due to the hassle.
I think in Stevens case, with all his mods then you can justify it as its all part of the jigsaw but on its own, not really convinced tbh.
MB
Old 02-13-2007, 03:21 PM
kstokell's Avatar
I've done it and it is definately a PITA job. I would not rcommend it unless you have the inlet manifold off for some other reason, then it makes sense.
Old 02-13-2007, 03:26 PM
A7DY W's Avatar
Did you notice any difference in performance with this mod???
Andy
Old 02-14-2007, 07:04 AM
kstokell's Avatar
No but then I fitted it when I fitted my SC so your not going to see a few HP whan the SC is adding 90 odd at the wheels.
My main reason was to keep the inlet side a cool as possible as the SC of course increases the air temperature even with the after cooler.
Matty_Vr6
02-05-2013 05:14 PM
1.8TsBLOW
11-08-2006 04:47 PM
FIdreaming
08-16-2006 09:29 AM
Asura
08-19-2005 07:19 PM
swtazn97
04-21-2003 10:43 PM
Quick Reply: Hondata Heatshield Gasket
