Holes above rear number plate
Pre-facelifts have a hole/gap which you can access the number plate lights through with your hand. They have a cap, with small hole in it, and the bulbs twist fit into the top side.
The facelifts have more of a traditional cover/shield system.
The pictures you've just posted CynicG are perfectly correct.
Slightly off topic but my entire number plate surround has dropped on one side (facelift) after I took some stones out from the lower part. They were obviously holding it on position! Looks like it was held in place with a double sided tape or something. Does anyone know how to take it out and re-seal it?
Hope this helps.
On the lines of this thread I have a couple of questions, the of which somewhat arose from reading this thread. I have the earlier dome shaped lights.
1) it was said the bulbs are twisted out. Ok, but how do you remove the dome? are there 2 screws either side to unscrew? if it is, mine have rusted to a crusty rusty blob either side that no screwdriver would work on. If they are screws I can use grips to get the out and replace the screw.
2) the connector coming off the plate lights connects to the cable coming out the back of the car (which has the fog light connector on also)But where do the join connectors sit? i.e fix to besides dangling loose. I cannot remember what held it in place but I recall it was metal and very rusty and the rust swell had slit the fixing hole (electrical connections is fine). I assume its on the bumper, there is a small tab on the number place piece. But I cannot visually it now. Any one who could take a photo would be of help.
cheers
cheers
The whole assembly comes out by removing two screws on each piece. The heads for these face the front of the car (you are looking at the thread end if you can imagine it).
Easiest, and quickest way to remove these most efficiently is to take off the whole rear bumper (I could do it with my eyes shut now, haha).
Don't forget to disconnect the loom for the lights before pulling right off.
Then you'll get good access to taking the assemblies off. I also gave them a good clean and soaping in the sink before re-fitting.
trustafox - These photographs in my thread may help your situation: https://www.s2ki.com/s2000/topic/101...t__p__23077132
I would say that bottom mounting plate has probably droppped due to a rusty or missing bolt.
As astage mentioned, it's probably a good idea to get all the rust treatment and underseal sorted at the same time.
I didn't mean how to remove the whole plat light unit but just the domes. I've have the bumper off a while and all parts removed here. I just cannot remember how the light connector is secured.
One thing looking at your photos, did one of the plastic plugs on the recess panel you screw in to shear off as you tried to remove a rusted in screw?
PS your plate recess brackets were positively in great condition compared to mine. Mine just crumbled between your fingers and none were just one piece! As you tapped the bumper fragments of rust kept dropping on the floor. At that point I'd never seen behind there so it was a mystery as to what I would find. I just hoped the body wasn't falling apart!
