HKS SC kit topic
Old 08-07-2016, 07:34 AM
  #771
E4RTH WORM JIM's Avatar
Get the code off Will.....
Old 08-07-2016, 07:40 AM
  #772
Originally Posted by markforrester99
I always thought that chargecooling was better. I know you tend to get more boost if i remember correctly as you haven't got all the long intercooler pipework. Water is also so much better at dealing with heat. At idle you would probably have to fit some fans to the cooler to keep the airflow high enough to keep the temperatures down
Would be interesting to see someone chargecool the HKS kit as looking at it it wouldn't take much to do but the costs would be pretty big. I would imagine £1000 with a decent chargecooler and radiator set up
Yeah if you can keep the fluid cool. Not so good once heat soaked.
Also, the charge cooler needs to be big enough after the SC to cope with the boost levels.
I could do with an ice/dry ice box aswell
Old 08-07-2016, 10:42 AM
  #773
Define198's Avatar
Honestly i feel at this point like he is not interested, and has pretty much said go away and buy a new radiator, but then everyone on here is saying the stock radiator is fine... So i just don't know, i feel like he wont give me the password if i ask, why would he password it if he would let someone else go into the map..
Old 08-07-2016, 12:20 PM
  #774
It's your car and ECU so tell him you want the password.
You can replace the radiator and like he said it may be that... But you want to be able to data log and use your ECU and he has locked you out of it!
I don't see why he wouldn't give you it.
Old 08-07-2016, 12:54 PM
  #775
markforrester99's Avatar
Not being able to access the data logging means your buying half the product. Ask him for the password so that you can set up datalogging and if he asks why just say its so you can accurately see under what conditions it gets hot.
Old 08-07-2016, 01:53 PM
  #776
If you have any issue then remind him that it's your ECU.
Let us know how you get on
Old 08-07-2016, 02:51 PM
  #777
s2konroids's Avatar
Some tuners class the map as their IPR.
Personality I don't lock them.
Old 08-07-2016, 11:51 PM
  #778
johnckeen's Avatar
Thats ridiculous...
If my tuner password protects my ECU i would not stand for it, you are paying him to tune it so you are buying the map!
If he wont give it to you then I'd take it to claims court as you've paid for it, its your property not his.
Old 08-09-2016, 09:01 AM
  #779
Define198's Avatar
got the mishimoto xline radiator on, the radiator fins where damaged in several places on both sides, which i was pretty annoyed about especially since it is brand new...
Anyway it has helped things with temps, but it is still rising higher than it should, i left the car idling in the garage with the bonnet up for a good 10minutes and the fans did not turn on once....? took it for a blast and the bars still went 2-3 higher than what they should be, pulled over and the fans were working.
one side
other side
i should of probably sent it back, but wanted to get the car sorted...
Old 08-09-2016, 11:26 AM
  #780
yorkies2k's Avatar
Have you looked at more obvious cooling issues like is your thermostat working correctly and are there any airlock a in the system?
Quick Reply: HKS SC kit topic
