HKS SC kit topic
#531
What time are you going to croft yorkie? I live in Newcastle, might pop along to look at your car. I've always wanted to check this kit out!
#532
Boys with the charger, or anyone in the know, what would you considered a good/safe minimum oil pressure reading on warm tick over? I have my low alarm set at 26 psi and it keeps momentarily blipping down to 23/24/25 which is causing the visual alarm to flash on occasion.
Having read a few US threads, where Honda state 36 psi and hot cars are anywhere in the 12-20psi region, I wonder if this lower alarm is way to high? Or if I should use 10w40 to help keep pressures up when hot...? (I appreciate HOT in the US is very different to HOT in the UK)
#533
At 800rpm I used to get about 17-18psi with it at 1100rpm I get about 24psi. When I get to 3000rpm im usually at 85psi and this drops to about 80 during vtec at high rpms.
I don't set the alarm on my spa gauge as really you would want the alarm at 65 psi so that it warns you during full throttle and vtec that the pressure has dropped, problem with that is that it will always alarm during idle and low oil pressures. 26psi at 8000rpm isn't going to save the engine from destruction.
#534
Thanks for response.
#535
Out of interest the guys who have fitted this kit what restrictors did you chose?
I'm thinking of machining the 37mm restrictor to 44mm(fuel upgrade kit size) just because i don't need 380bhp. It would be interesting to hear what restrictors you've used and what output you've achieved.
#537
Originally Posted by yorkies2k' timestamp='1460483923' post='23935984
Mine also still going strong. At Croft this Sunday.
I took standard donut off to fit oil cooler sandwich plate. Toyed with remote mount and may go this route at some point.
Your best upgrading clutch prior to fitting as just makes it more awkward to change later
There all day
#540
UK Trader
If any of you guys are interested in taking the next step in getting more power to your S2000 and fancy some bedtime reading I have the install instructions and can email them over.
I always keep at least one kit in stock
Please note the current RRP has now been reduced by HKS so its a great time to buy!
http://www.hendyeshop.co.uk/gt-super...06-18801-p.asp
Happy to do a mini group buy for up to 5 people with a good discount.
