HKS SC kit topic
Old 06-16-2015, 08:24 AM
  #441
UK Trader
Si@Hendy Performance's Avatar
HKS Europe are watching/reading this as I type.
1st check the traction fluid level, there should be an adequate level and that the oil is pumping ok.
2nd please check the tension on the belt.
Old 06-16-2015, 10:17 AM
  #442
markforrester99's Avatar
On your now video the coolant fans are also running which will make alot of extra noises in the engine bay. Does the HKS compressor oil use any sort of inline filter? If so might be worth checking it for anything suspicious.
Old 06-16-2015, 10:32 AM
  #443
yorkies2k's Avatar
Ryan, what's the noise like when you Rev the engine?
  #444
tron2k3's Avatar
At a guess looks like pulley or belt related, comparing the vids the second one looks like it's not spinning at speed compared to the first vid and the noise seems to be coming from that area when you pan the camera over it.
Old 06-16-2015, 10:34 AM
  #445
tron2k3's Avatar
Is there any movement in the pulleys?
Old 06-16-2015, 10:38 AM
  #446
yorkies2k's Avatar
The belt does look loose on the second vid although difficult to tell as you move around a lot
Old 06-16-2015, 10:41 AM
  #447
Ryan9's Avatar
It does use a filter, but if I take it out I don't have a filter to replace it with or more oil.
I tightened the belt and the noise was still the same, the pitch changes with rpm.
The pulleys seem fine, no play in them. I'm fairly certain it's coming from the s/c, you can hear it resonating through the air filter.
Waiting to see what HKS Europe say tomorrow, Si is on the case.
Old 06-16-2015, 10:50 AM
  #448
tron2k3's Avatar
Might be worth checking along all the mounts and bolts along the intake pipe and the bolts to the supercharger as any lose vibrations could travel through the pipe and resonate.
Si will sort you out
Old 06-16-2015, 10:52 AM
  #449
CynicG's Avatar
Agree - you can see it oscillating. How lose was it when you tightened it?
Old 06-16-2015, 10:55 AM
  #450
Ryan9's Avatar
Not massively loose, I think the look of oscillation is actually the cord/writing on the belt going around.
Quick Reply: HKS SC kit topic
