HKS SC kit topic
Old 11-28-2020, 09:22 AM
  #2201
hondajonno's Avatar
8550 was discontinued as far as I know.
Old 11-29-2020, 09:13 AM
  #2202
markforrester99's Avatar
Thanks for the reply Jonno,
Those figures are quite disappointing to be honest the rated output for that blower is 345hp-540hp. Out of interest what were your inlet temperatures? You can also reduce heat alot by fitting the bypass valve on the hot side of the supercharger. This means that when you are cruising you arent sticking warm air through the intercooler all the time. I have it before the intercooler and it means the intercooler is always nice and cool for when you want it to come on boost.
That contact would be useful if you dont mind sharing it. What else did you have to do to get the kit to fit? I looked at the drawings and it looked like it would need a 6mm spacer to get the charger to align in the same place as the 7040
Old 12-01-2020, 04:50 AM
  #2203
Define198's Avatar
Do you know what PSI you managed to get with the new blower? Also expected a lot higher numbers then 10%
Going by that you did not even break 400whp?
I think for the cost of the charger, pipework and intercooler i would be wanting to break 400whp, otherwise may as well go turbo or a different brand.
Old 12-01-2020, 04:43 PM
  #2204
hondajonno's Avatar
Had to put the spacer, refab the pipping to the charger. The spacing is tight for the pipping but according my mechanic not much work is required.
Old 12-01-2020, 04:44 PM
  #2205
hondajonno's Avatar
It’s going back on the dyno tomorrow with the smaller pulley and see if that helps with the power. Still on the stock kit intercooler.
Old 12-02-2020, 03:29 AM
  #2206
Define198's Avatar
Be cool if you could post the dyno sheet
Old 12-04-2020, 06:29 AM
  #2207
johnckeen's Avatar
yeh let us know all the details like psi etc
Old 12-18-2020, 02:25 AM
  #2208
bseriesblaize's Avatar
where did you get the adapter plate for the BOV? what spring rate and model BOV are you running also?
Old 12-23-2020, 01:25 AM
  #2209
does anyone have a picture or diagram that shows how the HKS relief valve is supposed to be assembled?
Old 01-19-2021, 01:45 AM
  #2210
johnckeen's Avatar
What is the recommendation these days for replacement spark plugs? I should probably change mine as they have done 3 hard years, currently running HKS ones but cant remember what version doh!
Quick Reply: HKS SC kit topic
