HKS SC kit topic
#171
UK Trader
Awesome!
#174
Tron
Make sure you let us know how you get on out on track. The sort of things i want to know is how the intercooler handles the heat of a trackday and whether you feel power tailing off as inlet temperatures rise. It does seem pretty quick from the video
Do they give you any guidance on how often the supercharger oil should be changed? How is it pushed around the charger does it have a pump built into the supercharger?
#175
Tron
I need to check the manual/instructions, but I think most are usually 50k miles. I believe there is some sort of pump in the charger when it spins. It's also attached to a cooler.
#178
Me too, can't wait to fit my TTS kit this summer!
#179
Tron
Traction fluid - Replacement not necessary, add oil only if needed.
Traction fluid Filter - Replace every 5 years or 70,000km
Air Cleaner - Replace every 2,000 - 3,000km. Filter maybe need to be replaced earlier than the above recommended intervals depending on the filter condition.
