HKS SC kit topic
Old 05-23-2017, 04:43 AM
  #1721
har-vey's Avatar
Anyone have a engine torque damper that fits with the HKS kit? my inlet pipe is connecting with the bolt on the side of the ABS.
Old 05-23-2017, 05:04 AM
  #1722
johnckeen's Avatar
Have you not fitted the brackets to your ABS pump for moving it towards the wing by a couple mm?
Old 05-23-2017, 06:07 AM
  #1723
har-vey's Avatar
Yes that is with them fitted. I'm tempted to remove the bolt as there are two more holding the ABS pump onto the bracket. It would gain me the clearance i need.
Old 05-23-2017, 06:44 AM
  #1724
Define198's Avatar
is their plenty of room to remove the oem oil filter(with no sandwich plate) without having to remove any of the pipework? i presume from under the car?
Old 05-23-2017, 06:47 AM
  #1725
har-vey's Avatar
Why don't you have a look and let us know
Old 05-23-2017, 07:38 AM
  #1726
Define198's Avatar
i can see, but i have never removed the oil filter, and i have no idea how far it needs to be screwed out to remove it, i presume it screws onto a threaded spline or something? just thought it would be a fairly simple answer from others who have removed it, i know it is not possible to run a full sized filter when you have a sandwich plate
so unsure if you can remove the standard one with the hks pipe so close
Old 05-23-2017, 10:33 AM
  #1727
CynicG's Avatar
It can be removed and a replacement fitted by hand from underneath. Tightening it up with a strap was a total pita (I was on jacks not a ramp) and found I couldn't get the filter tool on the end to use a spanner. This just made me paranoid about it coming loose.
Given I will be doing this several times a year, the relocation was a no-brainer.
Old 05-24-2017, 02:43 AM
  #1728
Define198's Avatar
awesome, hopefully Honda wont moan too much about the lack of space, i dont have the under trays on the car anyway so shouldn't be a problem for them with a ramp
Old 05-24-2017, 04:59 AM
  #1729
johnckeen's Avatar
Undertray doesnt get in the way when doing it from underneath...
Make sure they put in 5w40 as anything else is not recommended by HKS.
I had to disconnect the pipe from the back of the charger so i could move it up to clear the filter.
Old 05-24-2017, 06:25 AM
  #1730
Define198's Avatar
i am supplying them with castrol edge 5w40, which i do at every service, do you have a sandwich plate?
Quick Reply: HKS SC kit topic
