HKS SC kit topic
Old 04-16-2017, 02:45 AM
  #1561
Define198's Avatar
Sounds like a friend of mine has had his impellor snap on his hks kit, around 1.5 years of use, and sub 10k miles on it, he also suffered the flutter on his, so not sure if that has contributed to it happening
Old 04-16-2017, 07:26 AM
  #1562
Member
Bodyboarder1981's Avatar
Did he address the flutter issue or just leave it ?
Old 04-16-2017, 08:14 AM
  #1563
Define198's Avatar
Think he did eventually, not sure how long after though.
Hopefully the 6 months or so that I have run with the flutter hasn't weakened mine, not saying it is down to the flutter, could be anything I guess but could be a culprit.
Got me worried about mine feeling down on power
Old 04-16-2017, 08:44 AM
  #1564
Member
.....'I don't think this would cases power loss . It would be fine one day and then snapped the next , pretty sure it wouldnt be a gradual .
Old 04-16-2017, 08:54 AM
  #1565
Define198's Avatar
No neither do I really, he said it was fine and then no strange noises just lost all boost randomly
Old 04-18-2017, 12:01 AM
  #1566
Mike RT4's Avatar
Are you using the Mikalor hose clamps (as they are complete rubbish, and don't seal properly)?
Old 04-18-2017, 12:06 AM
  #1567
Define198's Avatar
im using everything that came with the kit, so all the original clips
Old 04-18-2017, 12:28 AM
  #1568
markforrester99's Avatar
The clips that come with the kit are nothing special but its not a serious amount of boost going through the pipes and all the intercooler pipework has nice lips on to ensure a nice tight fit and seal.
Defines issues are going to be hard to pin point without any datalogging ability. Feel bad for you as your tuner has well and truly stitched you up
Old 04-18-2017, 02:49 AM
  #1569
johnckeen's Avatar
https://goo.gl/photos/oApLXPvjc99tS6kx9
Here are the print outs lads. No flutter at all, no leaking from the EGR valve blank, ran sweet as a nut.
He had to zero out the idle control table as there was some sort of software glitch causing it to always ask for 55% duty even though it was at like 1800rpm which was causing the over revving and holding whilst driving. Max it can get now is 35% which is perfect.
Pulls like a god damn cat with a fire stick stuck to its tail, bloody epic. Even had flames come out the exhaust on the limiter ha!
But here is the thing that is really going to blow peoples minds... the contitec belt is a piece of shit, it slipped everywhere, now i knew this so took the old HKS belt with me just in case and oh what do you know, i have the HKS belt fitted and no slip at all, the HKS belt is perfectly capable of handling the charger.
Old 04-18-2017, 03:20 AM
  #1570
Define198's Avatar
was your contitech belt squealing?
all i can say about my hks 6pk1319 belt is that it squealed at anything above 7krpm at maximum tension at only a few months old
whereas the contitech does not squeal, whether it is slipping i dont know, but could explain my strange power loss
i dont really have a great urge to spunk out £70 on the hks belt for it to only last 2 months
Quick Reply: HKS SC kit topic
