HKS SC kit topic
#1551
is that with EFI? will be interesting to see what it makes.
I'm still convinced mine is down on a lot of power. I dont want to tighten the belt too much in case i damage the pulley bearings.
i think i need to invest in a boost gauge
#1552
Yes always with EFI.
My belt slips at the top end and I am reluctant to tighten it anymore like you say. I will get Chris @ EFI to have a look and tighten it as I do not trust myself, last thing i want to do is damage the charger!
I suggest you book yourself in with Chris and get him to have a look at it, he has done two of us now and doesn't password protect the files
#1553
#1554
also just paid out for new discs and pads as they were down to the metal, and then need two new rear tyres, even with the lack of tread my car is keeping traction, which i find highly strange.
How do you know yours is slipping? i have not yet had the "belt squeel" which i had with the original HKS belt, is yours squeeling on the top end? not sure if it can still slip and not squeel, but something is not right with mine
#1555
Did you not get a dyno print out when you had yours mapped? Or you recon it has lost power since the map?
#1556
I noticed a significant improvement in power when i changed my old filter for a new one but power seems to be down yet again so im really not sure whats going on with it
when the car was mapped it was literally the warmest day of the year, and it felt stupidly quick, spinning wheels and going sideways in 1st gear, it now feels rather tame. especially on the top end the revs just seem to slow down when going at speed 70+mph
#1558
If you can't see data logs then you need to fit a boost gauge. When I first installed my kit I had belt slip at 7psi onwards and never once did the belt squeal. Since then I've had no issues at all but I stuck with the orignal hks belt that everyone said didn't fit. Define you need to get your map sorted as your tuner has you over a barrel and you would never be able to see what your engine is doing if you had a sensor issue etc.
#1559
What are people going to do with these supercharged cars once you want to sell them ? How easy is it To take it all off and put back to standard?
