HKS SC kit topic
#1321
I have vibratec engine mounts and they don't have alignment marks on them so when fitting its a case of getting them as close to OEM positioning as you can by eye which might explain why my engine might be further over.
#1322
Do you get any horrible vibrations with these mounts?
#1323
No they are much much better than the Megan mounts i had before. Just annoying that you have to do some guessing when fitting. I took the brackets off of the block on either side, fitted the mount to the bracket and then reassembled. Got there in the end.
#1324
I'm pretty sure I've got spoon engine mounts on mine (as well as the spoon gearbox mount). I'll try and take a picture next time I'm under the car.
On a sidenote - where can I buy those pesky honda trim clips? I basically broke them off when removing my wheel liner.. Found on eBay. Bag of 9mm clips for under £3. Beautiful.
#1325
Dont go to honda for those clips... they wanted £38 for a dozen... i laughed and walked out.
I have the standard oil cooler, sandwich plate and standard filter installed, the pipe rests on the oil filter but it doesnt matter as you can just take he back pipe off and you can change the filter...
#1326
Plastic Trim Clip Kit for Honda S2000- Full Set of Wheel Arch & Undertray Clips | eBay
I now have plenty of spares for the future, well worth the investment!
#1327
i purchased a full set of them from ebay, which contained all the different sizes required for the full bumper and both arch liners
Plastic Trim Clip Kit for Honda S2000- Full Set of Wheel Arch & Undertray Clips eBay
#1329
#1330
Have you sorted your W/Meth issues?
