HKS SC kit topic
#1302
Hi. I am after a few bits. What would be the best bolt on kit to boost my sk2?? It's an import but I do take it on Trackday so want as much bhp as I can get without blowing anything up. I have been told you can't do much to the s2000 to improve on horsepower.? But from looking at the forum it would appear that's not the case.
Also I am after updating the brakes to a bigger brake kit. Any idea where I can get the bits?
Thanks
Mark
Thanks
Mark
#1303
Hi Hi -
Who's got a crankshaft tool they can lend me? I can come up to you if you are in London / Surrey area. Barring that any ideas on how to remove the damned thing? I've tried to blowtorch and Plusgas the bastard but no dice..
#1304
I bought mine was on eBay mate, only about £20 and an absolute must! Had to use a 5ft jack pole over a breaker bar before I finally managed to get the bolt out - after splitting a cheaper impact socket!
#1305
Either:-
-Take the car for a drive and get it nice and hot, Chock all 4 wheels, stick her in 6th gear and that should be enough lock to stop it from turning over. Use a can of compressed air, turn it upside down and squirt the bolt as this will freeze it, this process worked perfectly for me and came out with a 2ft 1/2 inch breaker bar.
-If you're lazy or ghetto, get a breaker bar wedge it against sill or subframe, remove fuel pump fuse and just gently bump the starter motor, this should also undo the bolt.
There are a few videos on here showing how this is done.
Trunkz (12-27-2016)
