HID Headlight Height Adjustment - How?
Old 12-14-2005, 11:54 AM
Shark75's Avatar
Default HID Headlight Height Adjustment - How?
I still haven't got a UK owners manual for my JDM S2000, so is there anyone out there kind enough to tell me how to adjust the height on HID headlights as on low beam i can't see where I'm going as they're not pointing high enough up.
Possibly scan the page in from the manual that tells you?
Assuming it can be done of course.
Old 12-14-2005, 11:56 AM
Paper Lawyer's Avatar
I asked for this at the dealer recently but apparently they are self levelling so bugger all adjustment.
Old 12-14-2005, 12:05 PM
S2KPDQ's Avatar
Yes, they are self levelling, but only assuming they are set correctly in the first place
There are two white plastic screws/'toothed wheels' which are turned (vertical and horizontal movement of the bulb) using a philips screwdriver - the instructions have been posted on here before - if only the search worked
I believe they can both be accessed from the engine bay though - but could be wrong and the wheel arch liner(s) may need to be removed.
Andy
Old 12-14-2005, 12:06 PM
That does ring a bell now you mention it Andy
Old 12-14-2005, 12:41 PM
Administrator
AquilaEagle's Avatar
PM sent
Old 12-14-2005, 01:02 PM
michael ferguson's Avatar
I think you have to take the units out to adjust them, I did. I think thats why their are made to be self adjusting as they are so awkward to get at without removing them. Although it might have been my induction kit getting in the way, but, I cant see how you could possibly get at the adjustment through the engine bay.
Old 12-14-2005, 02:17 PM
S2000_UK's Avatar
I thought Auto-levelling only came in 02 onwards (Chrome) headlamps?!
Old 12-14-2005, 02:58 PM
SiDHEaD's Avatar
I adjusted mine with a trusty screwdriver thru the specially made holes to the adjuster screws, no need to take the units out. They were set way too low by standard !
Old 12-14-2005, 03:10 PM
Shark75's Avatar
Need a blooming long screw driver to get through the hole . Is it philips or flat head required?
Old 12-14-2005, 03:52 PM
Beardie's Avatar
Is it okay to post this? Wouldn't want to upset anyone.
Quick Reply: HID Headlight Height Adjustment - How?
