Help required RE wiring problem
Hi all, I have fitted the new style center console tonight and come across a simple problem.
The connectors are different for the heated screen. I think its because the new style switch also heats up the door mirrors aswell as the rear screen.
Do some models have different switches depending on options? Im Hoping I can source a new switch that only heats up the rear screen in the hope that it has the same connector as the older style switch.
I dont mind cutting the wires to fit the new connector if I have to but I really want to keep the wiring as it is plus I dont have the new style connector and I doubt Honda will supply a connector on its own.
I may have to contact a breaker to obtain the connector
Hi
I looked into this a while ago, and a mate managed to wire up the old button to the new. It does not matter if you have heated mirrors or not.See below for the wiring diagram. I hope this helps
My Webpage
My Webpage
Thanks for the reply, the diagram I can loosely follow the diagram but ideally I could do with knowing which wire does which on the switches.
The old style swith has 6 wires and the new connector has 6....
Hello mate, while searching around I found this page, I hope this helps you with your wiring problem!
https://www.s2ki.com/forums/index.ph...c=621104&st=50
wirebrat
06-17-2012 11:46 PM
razorsharp192
01-20-2012 09:36 AM
Mannn
02-05-2004 06:48 AM
