Help please - replacement engine
#31
Originally Posted by hazdjc,May 15 2007, 09:32 AM
As AE has said try and get the engine with the clutch and gearbox, get yourself a S2 workshop manual and fit it yourself (its easy) or get a local HD to do it for you.
Dave
Dave
#33
Originally Posted by AquilaEagle,May 14 2007, 08:21 PM
I didn't with mine
05 engine with 02 ECU
Been fine
Why do you think the need to change Nick?
Been fine
As I'm crap at remembering names, I cannot recall who it was, or even if it was because it was a JDM car, thinking about it further!
#34
I dont really see the point in shelling out for a gearbox when mine is probably OK. I have a spare full clutch and flywheel already.
There appears to be splt advice between compatability of 2004+ engines with regards to matching my gearbox/prop shaft/ecu??
Does anyone have any further comments on recon engines with warranty - isn't this a safer bet than a salvaged one?
Money is the issue here, I hadn't budgeted for a failure - but obviously don't want to cut corners either. If it comes out Ok I may even renew my membership
#35
Originally Posted by Nick Graves,May 15 2007, 11:20 AM
I thought someone had to, in order to cure running issues.
#36
Originally Posted by Paper Lawyer,May 15 2007, 09:39 AM
How about Chilled and Lurking Lawyer fit it, using nowt but a Halfords Professional toolset and their ingenuity? I'd quite happily contribute towards their liquid lunch to watch that
#37
Originally Posted by Lurking Lawyer,May 15 2007, 11:20 AM
Oh ye of little faith!
Assuming your bro still lives near me you can kill two birds with one stone.
Craig, I'll buy him a barrel if he can perform the surgery!
#38
Originally Posted by Jel,May 15 2007, 12:28 PM
Does that mean you'll do it?
(PS If you were in fact mad enough to let me anywhere near your car with anything more technical than a screwdriver, you'd be completely off your head )
#39
I think its better to replace the engine & gearbox, as they came off the one car and they will be compatable. at the same time you can change the clutch. It so easy when you look at the Honda Workshop Manual it take you step by step.
I wouldn't trust getting a recon engine, even with warranty.
Send Man an e-mile he's changed his and we did it over a weekend with the help of Chris (CG)
dave
dave
