Help please - Hot wheel.
I would put money on the slider grease. I have owned two honda's now and they have both suffered sticky sliders. Even when i grease mine when i next go to check my brake pads i normally find the sliders are abit sticky.
At least the S2000 caliper has flats on the slider so if its seized you can put a spanner on it and work it back and forth until it becomes free.
Tell tale sign of stick caliper slider is a discoloured brake disc visable through the wheels and also you will find that the brake pad on the outside (ie the one not next to the caliper piston) will have used alot more brake pad material.
This was my passenger side front after the sliders seized
The brake pad can be seen here, mine only seized for a couple of minutes until i stamped on the pedal and it freed off,
Um ok new issue. Taken the caliper off, sliders are free and fine. So we're trying to bleed the brakes to move the piston, came out fine but now it won't go back in...
...any suggestions?
...any suggestions?
I've also used an oil filter tool, the ones that are like large pliers to squeeze the piston back in using a piece of wood or something similar to prevent scratching the top of the piston.
