UK & Ireland S2000 CommunityDiscussions related to the S2000, its ownership and enthusiasm for it in the UK and Ireland. Including FAQs, and technical questions.
You don't actually need it and JDM VTEC engines have never had the VTEC oil pressure switch.
My engine doesn't have it see
If you are in a pinch you can find a 5v out and bridge it - this is what I did when running a UK P28 ECU with a JDM b18C to save me buying a new VTEC Solenoid.
Mark, i snapped it clean off so there was a plastic ring left eg take a small vertical slice of a coke can 2mm thick. Pole with rod was intact. I guess it wont engage vtec if it was foooked?
Originally Posted by Hypersonik,Apr 22 2009, 09:35 PM
VTEC Oil pressure switch
Thanks for that Ron, interesting to see JDM dont have it.
I'm just concerned it will feck up
I'm gutted like very dissapointed with myself , i never really **** things up like this.
Originally Posted by Hypersonik,Apr 22 2009, 09:51 PM
It checks to see if oil pressure is enough before allowing VTEC to be engaged.
TBH, if this eventuallity comes to fruition, you have damaged your engine anyway and it isn't an RPM cut either.
I have no idea why Honda saw fit to put it on European/American cars, but the Japanese cars, with VTEC engines, have never had them.
Thanks for that Ron
So for time being order one but ill be fine? i will still fit another can i not just fit the item i broke? as it has a hex on the end of it.
Shame as after i finished servicing car, it was running like a champ.
Oh Ron heads up for you...have you changed the oil filter and took off sump plug yet?
A) It was a bitch to take off the oil filter due to the engine torque damper, i did it eventually, then when putting the new one on in a hurry as the missus had brought back fish and chips and slipped and snapped the above item
B) The ebay cusco copy lower front brace makes taking off the sump plug more difficult, depending on what tool you have i had to get another tool.
