Help needed
Help needed
I have the car in for an MOT, however the guy pointed out the fuel line has some "slight" corrosion just at the bends, he is now away for a day.
He said it "probably" would not pass the MOT, can anyone tell me if theres only one fuel pipe and which one it would be? (Maybe theres only one! ).
IIRC if looking from underneath the car, the pipe runs along the lefthand side from the front to the back, I think there's another pipe there too.
Cheers
Cheers
Originally Posted by MB,Jul 1 2008, 04:18 PM
Supply and return...
You dont have the legend by any chance do you?
I'm away from home again this week so i dont have the workshop CD with me
Member
19687 001 1 DAMPER ASSY., PULSATION No Color 34.22 23.95 Qty:
19688 002 1 GASKET, MUFFLER No Color 2.58 1.81 Qty:
204535 003 1 HOSE, FUEL FEED No Color 59.25 41.47 Qty:
204536 004 1 CANISTER ASSY. No Color 166.84 116.79 Qty:
1305402 005 1 VALVE SET, SOLENOID No Color 71.33 49.93 Qty:
1308408 006 1 VALVE, CANISTER VENT SHUT No Color 109.78 76.85 Qty:
34653 007 1 FILTER, CANISTER No Color 29.99 20.99 Qty:
204538 008 1 JOINT (#85) (TWO-WAY) No Color 4.87 3.41 Qty:
204539 009 1 BRACKET, CANISTER No Color 47.59 33.31 Qty:
204540 010 1 STAY, FUEL VENT VALVE No Color 10.55 7.38 Qty:
204541 011 1 VALVE, TWO-WAY No Color 52.91 37.04 Qty:
204542 012 1 TUBE, CANISTER No Color 4.23 2.96 Qty:
204544 013 1 TUBE, DRAIN FILTER No Color 3.03 2.12 Qty:
204543 014 1 TUBE A, DRAIN No Color 3.39 2.37 Qty:
204545 015 1 TUBE B, DRAIN No Color 3.03 2.12 Qty:
29517 016 2 MOUNT, BYPASS SOLENOID RUBBER No Color 3.28 2.30 Qty:
204546 017 1 BRACKET, RUBBER MOUNTING No Color 11.84 8.29 Qty:
204547 018 1 COVER, CANISTER No Color 37.19 26.03 Qty:
204548 019 1 PIPE, FUEL FEED No Color 25.86 18.10 Qty:
204549 020 1 TUBE ASSY., CANISTER No Color 5.98 4.19 Qty:
21142 021 1 CLIP, FUEL PIPE No Color 0.90 0.63 Qty:
204550 022 1 TUBE A, PURGE TANK SENSOR No Color 2.73 1.91 Qty:
204551 023 1 TUBE B, PURGE TANK SENSOR No Color 1.86 1.30 Qty:
204552 024 1 TUBE ASSY., VENT No Color 6.81 4.77 Qty:
204554 026 1 PIPE, FUEL VENT No Color 21.47 15.03 Qty:
204555 027 1 HOSE, PRESSURE REGULATOR RETURN No Color 38.98 27.29 Qty:
204556 028 1 PIPE, FUEL RETURN No Color 19.80 13.86 Qty:
204557 029 1 CLIP, DRAIN TUBE No Color 3.36 2.35 Qty:
204558 030 1 JOINT, DRAIN TUBE No Color 3.39 2.37 Qty:
204559 031 1 JOINT, DRAIN (THREE-WAY) No Color 5.12 3.58 Qty:
204560 032 1 COVER, FR. FUEL PIPE No Color 22.32 15.62 Qty:
204561 033 1 COVER, RR. FUEL PIPE No Color 22.32 15.62 Qty:
204562 034 1 STAY A, FUEL PIPE No Color 4.21 2.95 Qty:
204563 035 1 STAY B, FUEL PIPE No Color 8.46 5.92 Qty:
204564 036 1 STAY C, FUEL PIPE No Color 3.16 2.21 Qty:
26546 037 1 SENSOR, VENT PRESSURE No Color 70.13 49.09 Qty:
596951 038 1 CLIP, FUEL PIPE No Color 2.24 1.57 Qty:
19730 039 1 WASHER, SEALING (12MM) No Color 2.70 1.89 Qty:
19646 040 2 SCREW-WASHER (5X16) No Color 1.53 1.07 Qty:
19795 041 1 O-RING No Color 3.65 2.55 Qty:
19647 042 1 O-RING (NO.1) No Color 3.08 2.16 Qty:
19648 043 1 O-RING (NO.2) No Color 4.08 2.86 Qty:
19534 044 2 CLAMP, FUEL HOSE (D10.5) No Color 2.34 1.64 Qty:
32173 045 1 HOLDER, DRAIN TUBE No Color 4.08 2.86 Qty:
34685 046 3 CLIP, FUEL PIPE No Color 1.78 1.25 Qty:
204565 047 7 CLAMP, FUEL PIPE No Color 4.20 2.94 Qty:
25232 048 3 BOLT-WASHER (6X16) No Color 0.84 0.59 Qty:
13171 049 1 BOLT-WASHER (8X16) No Color 0.25 0.17 Qty:
7055 050 7 BOLT-WASHER (6X16) No Color 0.68 0.48 Qty:
16388 051 2 SCREW-WASHER (5X8) No Color 0.68 0.48 Qty:
8918 052 2 SCREW-WASHER (5X10) No Color 0.68 0.48 Qty:
26552 053 1 BULK HOSE, FUEL (3.5X3000) (3.5X50) No Color 9.14 6.40 Qty:
19614 054 1 BULK HOSE, FUEL (5.5X8000) (5.5X65) No Color 47.07 32.95 Qty:
19615 055 2 CLIP, TUBE (B10) No Color 0.78 0.55 Qty:
941 057 2 BOLT, FLANGE (6X12) No Color 0.82 0.57 Qty:
373929 058 1 CLAMP, VENT TUBE No Color 2.72 1.90 Qty:
962498 059 1 CLIP, CABLE No Color 1.38 0.97 Qty:
75886 060 1 CLIP S, BRAKE PIPE
