HEL Performance 2012 Time Attack Build
Old 11-12-2010, 06:08 AM
  #61
HEL Performance's Avatar
Well, the shell went off today to Nickson Motorsport in Surrey to have the seam welding and roll cage work done.
What to do in the meantime? We got hold of front and rear subframes, and a steering column and rack to work on. Both frames will be seam welded for extra rigidity and strength, and then dipped and re-painted.
Looked at doing both subframes in T45 tubular, but given the amount of work it would take to do this on subframes of this size and complexity we'll stick with the original frames for now and maybe look at this further down the line.
Old 11-12-2010, 06:58 AM
  #62
biker1's Avatar
Are you ditching the ABS? thought about doing this on mine?
Old 11-12-2010, 07:10 AM
  #63
Oh definately. No need for the ABS on a race car.
Old 11-12-2010, 07:14 AM
  #64
The Loon's Avatar
What are your plans for the brakes?
Old 11-12-2010, 07:39 AM
  #65
Brakelines will obviously be made by us, and we're one of the only brakeline manufacturers in the world who do titanium fittings, see below, which we'll use on the car. We'll run the lines through the car in one of our funky coloured hoses no doubt.
Calipers will most likely be AP Racing, 6 pot fronts and 4 pot rears. Thats a little overkill for the car and power, but I'd rather have too much than not enough in that department.
And we always use Castrol SRF fluid, best fluid on the market IMO.
Old 11-12-2010, 07:44 AM
  #66
The Loon's Avatar
Nice
I agree with your approach. I'm running a Hi Spec kit
4 pot calipers with a 335mm 2-piece slotted disc, Ds2500s. They are great on the road and held up well at Rockingham
Good luck with the build
Old 11-12-2010, 03:53 PM
  #67
razzele's Avatar
^^ Looking good.
I m really interested to see what you are doing with the wishbones as the standard items are heavy and really soft.
Old 11-13-2010, 12:02 AM
  #68
E4RTH WORM JIM's Avatar
Originally Posted by razzele,Nov 13 2010, 12:53 AM
^^ Looking good.
I'd also be interested to see alternatives as you could really save some unsprung weight here!
Old 11-14-2010, 11:09 AM
  #69
msisleman's Avatar
Brilliant thread!
Old 11-16-2010, 07:03 AM
  #70
Dynax's Avatar
Those brakelines look fantastic! How much would a kit with titanium fittings set you back? And what are the advantages over running these fittings instead of stainless?
Had some normal stainless steel HEL ones fitted to my old EP3 and were great
Quick Reply: HEL Performance 2012 Time Attack Build
