HEL Performance 2012 Time Attack Build
Old 08-16-2011, 09:12 AM
  #641
Banned
rob2.2's Avatar
im pretty sure there just the wheels for mapping and rolling it around, the time attack wheels will be different
Originally Posted by chrisr111
Originally Posted by Fontal' timestamp='1313509034' post='20882771
I don't mean to be bad but what happens when the brakes heat up and the metal expands?
or when the wheels flex under load
Chris.
Old 08-16-2011, 10:45 AM
  #642
Tim S's Avatar
Chris.
...or when the uprights flex under load!
Old 08-23-2011, 09:53 PM
  #643
ADAM_ROB_UK's Avatar
Old 08-26-2011, 11:41 PM
  #644
HEL Performance's Avatar
Been assured by 'the horses mouth' if you like that all will be fine with the clearance, as scary as it looks. A £4500 replacement kit is on the line with that assurance so I'm happy with that.
Had the graphics guys in taking measurements this week, and now we are just waiting on TTS finishing the engine so we can get on with the mechanical build. In the meantime we'll be busy putting in the airjack lines and brake lines in the next few weeks.
Also imminently expecting the flocked dash and custom made Corbeau seats back to fit too...
Will be back with updates very soon.
Old 08-28-2011, 01:11 PM
  #645
Rob@ReidyRacing's Avatar
Sounds awesome mate! Looking foward to seeing it all come together. Be in touch next week
Old 08-29-2011, 12:07 PM
  #646
UK Moderator
chrisr111's Avatar
Was the horse Rota or AP?
FWIW and IIRC Brembo recommend 2 mm of clearance.
Chris.
Old 08-29-2011, 11:23 PM
  #647
It wasnt Rota put it that way There is 2mm (just ) so we should be ok but thought best to check we'd got the back up of the supplier first...
Chris.
Old 09-05-2011, 01:01 AM
  #648
Ok people, some engine info and pics........
88mm JE forged Pistons TTS machined to 10:1 custom spec.
Block is Darton sleeved and bored and honed to suit.
BC Engineering 97mm stroker crank and forged rods.
Giving 2360cc with an 8k rev limit.
ACL bearings.
Standard head with standard F20 cams and valve springs.
With the lower rev limit there is no need to go for an exotic valve train.
Old 09-05-2011, 03:09 AM
  #649
WinFreak's Avatar
There's nearly no metal left between the bores!
Old 09-05-2011, 03:02 PM
  #650
Banned
rob2.2's Avatar
there is loads of material left
why are you using a complete stock head with cams, valve's, springs and retainers?
Quick Reply: HEL Performance 2012 Time Attack Build
