Heavy clutch pedal
Old 08-16-2010, 08:35 AM
s2k_Nut's Avatar
Default Heavy clutch pedal
My clutch is very heavy it seems to me, I just drove my daughters fiesta for example and depressing the clutch on that is very easy and very smooth. My S however is tiring on the leg within a few depresses, is there a common, or simple solution to this?
Old 08-16-2010, 08:54 AM
Wobbly's Avatar
Here you go LINKY
Old 08-16-2010, 09:13 AM
s2konroids's Avatar
As above, however it didn't make a massive difference when i did it.
The few people on here that have drove my S say my clutch is heavy compared to other S2000's, which makes me think the clutch has possibly been changed at some point - the feel doesn't bother me TBH.
I drove Steve Pearsons MY04 and it is definitely lighter compared to mine.
Old 08-16-2010, 09:43 AM
E4RTH WORM JIM's Avatar
I bet if you look at your clutch fluid it's black.
A good flush helps aswell IMO
Old 08-16-2010, 10:20 AM
richmc's Avatar
Yeah, flush through the fluid, do the ball thing and whilst the slave is off get a torch and coat hanger and get some high temp greese on the fork where it contacts the bearing. Done mine, light and smooth clutch.
Old 08-16-2010, 10:27 AM
Bassoctopus's Avatar
Clutch fluid made mine a bit lighter.
AJ, I've done the same comparison and the 04 clutch was much lighter than mine too
Old 08-16-2010, 10:35 AM
S2000_FUN's Avatar
Originally Posted by Wobbly,Aug 16 2010, 08:54 AM
Here you go LINKY
Very usefull link. I have done this to mine couple of months ago and it cured the squicky noise. However it did not make any change to how heavy the pedal was. Clutch usually gets heavy with time. When is very heavy is due to a change. I have also heard from friends that cluch is light only very short time after the change and after gets heavy even if it's not still time for a change.
Old 08-16-2010, 10:55 AM
MB
Member
MB's Avatar
I'm surprised AJ didn't suggest working on the quads a bit more....
Old 08-16-2010, 01:40 PM
s2konroids's Avatar
Neil, good to know
The clutch fluid will go black in no time, a) there only .7 litres in there and b) because of the seals.
jhkim161
10-04-2014 02:07 AM
WRCGooseS2K
03-17-2014 12:25 PM
realmike15
05-04-2011 09:10 AM
Dragon Slayer
12-07-2007 05:56 AM
tothemaxx
08-17-2003 04:35 AM
Quick Reply: Heavy clutch pedal
