Heat soak kangarooing
#22
I had a very interesting discussion recently that I can't publish on here that basicly suggested that the whole heat soak thing was a red herring.
Now I don't entirely believe it because of a few of my own experiences however after the discussion I tried a few experiments and you wouldn't believe how much of it is down to people not being able to modulate the throttle properly.
#23
That sounds so much like XVIPER from the USA S2 Forum, he says its all down to throttle and clutch control!!! What nonsense, when its so abviously a car fault. I have owened 37 cars and driven a lot more and this is the first time I have known such a problem (my own car included). Heat soak or not there is a design fault somewhere...
#24
.... I'd like to think I've driven enough cars (including the same S2000 when the hot air under the bonnet has not been hot) to know that it wasn't me when it occured
I can actually get my hands on a 2" square datalogger that can measure the air temperature every second from work, I'm tempted to place this in the first compartment of the airbox. Go for a drive then try different air box 'mods' and repeat the drive, to see how much effect the air temp changes by - Just to try and settle this It all downloads into Excel so could be interesting.
I have already aluminium taped the entire lower half of the air box (out of sight and hopefully reflecting some heat from the rad/engine) next stage is the datalogger research
#25
Member
Ive got the MAP voltages on my PLX wideband logger, when the car goes into kangeroo mode. I will post them up soon. I purposely set it to record when i was in heavy traffic and caught it.
MB
MB
#26
Part of the problem is the inital loss of power caused by the heatsoak, but the rest of it is caused by the s2000's very immediate response to the throttle and very light flywheel which doesn't damp changes in the rate of change of revs in the same way a normal engine does.
#27
This is why I & others have removed the Rad shield, it cuts off at least 90% of available clean (colder) air to the Airbox IMO. All the Airbox has got to use is the air around the Rad and the 6 or so slits in the Rad shield.
Bearing in mind that the top of the Rad is just in front of the Airbox inlet and does get bloody hot what little air the box can ingest is not helped by then getting heated by the Rad.
All I can say is that I
