Headlight washers
Old 11-10-2007, 06:51 AM
Administrator
AquilaEagle's Avatar
Check your ressevoir is full the headlight ones stop working before it is empty, and the windscreen ones will still work until the resevoir runs out
Old 11-10-2007, 10:07 AM
Nick Graves's Avatar
IIRC there is a fuse and relay in an add-on box somewhere under the bonnet for the headlight washer pump. The switch side of the relay shares the fuse.
If you hear a relay click, you only need check the current is gatting to the pump.
You can easily squeeze off the circlip & pull off teh hose at teh pump. Get a friend to press the button & see if you're soaked.
britsportscars
07-22-2013 04:54 AM
NAREKS2k
01-20-2010 12:10 PM
Mok
06-08-2005 06:38 PM
bhav
08-14-2004 07:16 AM
Quick Reply: Headlight washers
