Headlight washers
Old 11-10-2007, 02:50 AM
eddiebee's Avatar
Default Headlight washers
I am a new owner and new to forum. I have tried a search but got no results concerning my inoperative headlight washers. I know from the handboock that the windscren and headlight washers share the same reservoir but do they have separate pumps? My windscreen set up works fine but when I try the headlight wash circuit all I can hear is a click coming from the drivers (RHD) footwell, I presume this is a relay. Any suggestions how to fix this?
Old 11-10-2007, 02:55 AM
Jel
Jel's Avatar
Has someone removed the fuse in the box under the bonnet?
Old 11-10-2007, 02:57 AM
eddiebee's Avatar
I'll go and check. Thanks Ed
Old 11-10-2007, 03:05 AM
Jel
Jel's Avatar
To be honest you are better off without them!
Old 11-10-2007, 03:19 AM
GavB's Avatar
Worth asking - are you trying with the lights on!
Old 11-10-2007, 03:24 AM
Kiwi-S2000's Avatar
Kiwi
Old 11-10-2007, 03:34 AM
Jel
Jel's Avatar
You're going to get really fat from all that popcorn you've been munching recently dude
Old 11-10-2007, 03:56 AM
Nick Graves's Avatar
Of course they have separate pumps!
The hadlight washer one is the high-pressure one up top.
First off, can you hear the relay click? if not, I bet someone pulled the fuse!
If it is, take the pipe off the pump (RHS wheelarch, behind the liner) & see if you get drowned.
Alternatively, look for puddles under the front bumper, in case the pipe has blown off.
Old 11-10-2007, 04:27 AM
I've just checked mine; there's 12V buzz to the pump, but no squirt.
My windscreen washer one went in the spring!
This has not been a good year for S2K VT.
20/20 hindsight: I should have taken it into the woods & shot it and kept the NSX.
Old 11-10-2007, 05:59 AM
eddiebee's Avatar
Kiwi what am I supposed to do with your reply, you have lost me.
According to my handbook there is only one fuse for "washer" so as the windscreen washer works I assumed the problem is elsewhere. I didn't know there were two pumps so thanks for that, I will check for power reaching the pump and/or pump buzzing. I said in my post that I can hear something clicking in the drivers footwell area, I presume this is the relay clicking. (By the way I did check with the headlamps on) Thanks for the suggestions I have a good idea now what to do. Am I right that there is only one fuse shared by both pumps? Cheers
ED
Quick Reply: Headlight washers
