Headlight Condensation
Old 09-19-2005, 03:08 PM
UK Moderator
UK Moderator
BSM139's Avatar
Default Headlight Condensation
I've tried the search engine, but I'm getting some weird results.
Just noticed that I've condensation in my driver's side headlamp Passenger side is fine. Car is 6 years old, and had it's annual service on Friday.
Can't see any cracks etc, and the headlamp still works, so is it a new light that I need or a repair job, or sit there with a hair dryer ??
Thanks
Bharat
Old 09-19-2005, 04:41 PM
S2000GT's Avatar
remove the light unit from the car.
remove ballast and bulbs and bake in the oven
225* for about 5-6 minutes to get rid of the moisture
when you remove the light, seal the joins with silicone
problem solved - did this to a friends car over the weekend!
Old 09-19-2005, 10:01 PM
cejsmith's Avatar
Get a new headlight on monday to get rid of this problem.
Old 09-19-2005, 10:37 PM
UK Moderator
UK Moderator
BSM139's Avatar
Baking in the oven is a bit difficult at the moment as due to house renovations, we don't have a kitchen
Does that mean that the seals are gone ?
If so, which seals are we referring to ?
Anyone else had this problem in their S ?
Bharat
Old 09-19-2005, 11:26 PM
lower's Avatar
if you can't bake in an oven, heating with a hairdryer inside and out gets rid of the moisture, just takes longer.
Old 09-19-2005, 11:34 PM
Shipley's Avatar
I had this last year....I disconnected the connections to the bulbs etc (mainly because I couldn't be arsed removing the light unit, people talk of high voltage and I don't do high voltage )
Lay the hairdryer in the engine bay so it is blowing warm air into the light unit. I left it on low power for about 10 mins and reconnected everything..making sure the seals were clean and well seated.
I haven't had a problem since.
Old 09-19-2005, 11:51 PM
micky22's Avatar
had this problem as well, only real way to stop it is to remove the light dry it out, i use a hair dryer then re sealed the lense. been fine for the last 4 months.
Old 09-20-2005, 12:12 AM
Crusoe's Avatar
LOL
All xenon lights are open to the atmosphere to vent the heat which they generate a lot more of than standard bulbs. Some misting and moisture is not unusual and turning on the lights for 5 min will burn it away.
Old 09-20-2005, 12:33 AM
pjsub's Avatar
That's what I did to mine and the condensation has never come back.
Old 09-20-2005, 12:57 AM
mikey k's Avatar
I had the same thing on my 00 car.
I went for a few weeks then I pressure washed it
I ended up using the S2000GT method with a twist. On top of a radiator with a dehumidifier pointing at it!
Redid the seals with expoxy resin glue
BTW argued the toss with HUK on the extended warranty that it was failure of the seals on a sealed unit. No luck
Japmuscle
08-02-2011 10:24 AM
smach
04-30-2011 01:25 PM
blobianco
10-09-2010 10:35 AM
brerspidur
05-30-2003 08:30 AM
enguyen7292
01-22-2002 04:29 PM
Quick Reply: Headlight Condensation
