Headlamp washer pump
Hi, anyone know of places to buy the headlamp washer pump (other than Honda)? I'm sure Ive seen a link for it (as a shared part) at Halfords for something like £8?
Thanks
Thanks
I think that was the windscreen one - https://www.s2ki.com/s2000/topic/103...ment-diy-guide
I think I have a pump at home that I removed when I de-washered my bumper - you want me to look when I get home ?
Yea mines gone too. I took the wires off and am getting 12v but no life in the pump. A new Honda unit is a bit pricey. I think I will pull the pump out, as its goosed anyway, and see if I can clean it up.
Pete.
Pete.
Wow, its no wonder it had stopped working. When I pulled the pump out a great lump of muck came out followed by half a gallon of water. Well I suppose it is nearly 14 years old.
New pump on its way.
Pete.
Pete.
Thanks all. Finally got chance to look - tested with multimeter and it was getting power fine. Took the pump apart and did get it going for a bit - but it then stopped (and then I managed to break the plastic impeller too ) - looked like it failed as the impeller was worn/rubber seal stopped it turning.
Managed to get a replacement and the part number is 22188 - its the same as some other models. Its a lot easier to fit with the wheel and wheelarch liner off too! So now all working and surprisingly behind the wheelarch it was spotless like new!
Wobbly
01-17-2016 01:12 PM
