Head unit question
Originally Posted by Lurking Lawyer,Aug 5 2005, 03:28 PM
And why does it need that particular gizmo then, O Audio Paper Lawyer....? Is it a must-have, bearing in mind that it's not going to get hooked to a whizz-bang amp and sub set-up like the Armstrong Wheels-of-Steel mobile disco
EDIT: here's some good further details. Also bear in mind you need to do correction for all four speakers in your car, as in this thread (don't forget the driver is on the lefthand side of the car either!)
https://www.s2ki.com/forums/index.php?showtopic=205252
Originally Posted by craig armstrong,Aug 5 2005, 04:35 PM
I take it you've not even adjusted your time correction then Mark?
OK - looks like it's the more expensive one then.
Lingus - sorry for completely hijacking your thread. I'll now vacate it!
Originally Posted by lingus,Aug 5 2005, 01:09 PM
Do you need a HU harness adapter for a JVC or Blaupunkt
and also if i wanted to put a Sub where my space saver is do i need to take it out??
and would that affect the balance of the car?
Ahh thanks Craig, yes i don't know if i will be using the dash controls so i better get a audio leads jobbi...
I've got a 9" sub that i took out of my VXT i was maybe wondering if i could butcher it and stick it where the space saver is.
Thanks all
Jeff
Thanks all
Jeff
yes i will need to make a mdf enclosure for it, i have seen the measurements somewhere i was thinking of putting the amp behind the seat maybe unless i can get it in the boot without taking too much space up.
You have seen a Wlaurent enclsoure haven't you? Perhaps more costly but easy and the amp can go on an amp tray where the spare tyre was then. But I'm biased, that's what I did (See photos in sig)
Yeah it's something like that, mines a 9" audiobahn bass tube, i don't want to butcher it but i may have to save spending more money on another sub.
s2k_chimp
12-27-2012 09:15 AM
